Author Topic: All the way from South Africa  (Read 133522 times)
Offline volvarine
« Reply #280 on: 30/10/13 »
Hi guys,
I bought a GT28. What you guys think...will it work? I want to get bigger injectors as well! What cc size are the current injectors?
Specs:
COMPRESSOR HOUSING AR.60
COMPRESSOR WHEEL 54.2MM
TURBINE HOUSING AR.64
TURBINE WHEEL 46.9MM
« Reply #281 on: 30/10/13 »
For daily drive use I still would recommend gt2540.
Stock injectors are 330cc. We are using 380cc injectors from 1JZGTE engine (23209-46070) and related fuel pump (23221-46070)
Offline volvarine
« Reply #282 on: 30/10/13 »
Thanks Uran! I think this car will be come more of a track car than for daily use.
« Reply #283 on: 30/10/13 »
You should be ready to get broken gearbox and low torgue above ~3000rpm :)
Offline volvarine
« Reply #284 on: 30/10/13 »
The way my car is setup now on the race map where I get full boost at <2500 rpms and lots of wheel spin I think a little bit of turbo lag would be good ;) I am hoping the good oil and gearbox cooler will help protect the gearbox a bit. I am not launching the car with foot on the brake pedal a lot either.
If gearbox do decide too give then it is time to go manual box.
« Reply #285 on: 30/10/13 »
Our experience shows that manual gearbox is weaker :(
You can change main gear ratio (more) to reduce turbo lag
« Reply #286 on: 30/10/13 »
You can take a manual gearbox from toyota 3SZ-fe engine, i think it will be stronger.
 I have some another ratio, but how much shiping will cost you?
Offline volvarine
« Reply #287 on: 30/10/13 »
Is the manual box weaker or does it break clutches?
I didn't think about changing the gear ratios! What ratio would you suggest?
Позже (30/10/13) добавлено:
Are you talking about the 2l or 2.2l toyota camry boxes 3sfe/5sfe motor?  Google translator is not good! :) Do you have a final drive gear ratio for me?
« Reply #288 on: 30/10/13 »
Manual gearbox breaks teeth of the gears.
I believe that for racing purposes the shortest gear ratio is best
Offline volvarine
« Reply #289 on: 30/10/13 »
breaks teeth! That is not good!
« Reply #290 on: 30/10/13 »
не всегда... обычно на мощности, приближенной к заводской - короткая пара дает преимущество, а когда идет повышение мощности (не обязательно кратное) - ставят пару подлиннее, чтоб не остаться буксовать и не увеличивать количество переключений.
« Reply #291 on: 30/10/13 »
эта очередная попытка объять необъятное в области автомобильного словоблудия? :) мы ж конкретный автомобиль обсуждаем, так? ;)
« Reply #292 on: 30/10/13 »
Вот именно, я, например, уперся в то, что на первой уже на короткой паре не могу стартовать (естественно, речь про драг и старт с 2-х педалей при включенной закиси).
Даже когда пробовал ехать с первой без закиси на старте и на ходу включал закись - улучшения динамики не было (относительно старта со второй), ибо колеса моментально срывались в букс.
Поэтому, сейчас у меня надежда на слики.
Но, поскольку, пока короткой пары хватает на 400м - останусь на ней, ибо коробке на ней легче живется.
« Reply #293 on: 30/10/13 »
3SZ-VE.
« Reply #294 on: 30/10/13 »
монопенисуально, внутрянка одна и та же, порвет ее на драге, тем более, гариком 28м...
« Reply #295 on: 30/10/13 »
я так для правильности :-)
Offline volvarine
« Reply #296 on: 15/01/14 »
My dad fitted the subaru 4 pot calipers and toyota runx RSi 275mm disks. I havn't driven it yet bcause the car is still with him but he says the braking is good! He needs to wash the car! :)
« Reply #297 on: 15/01/14 »
pretty nice set. congarts! Do you consider 4 pot enough for effective breaking?)
« Reply #298 on: 15/01/14 »
Nice mod! :) Do you have caliper adapter`s drawing with dimensions?
Offline volvarine
« Reply #299 on: 15/01/14 »
Thanks I think it will be enough. YRV is light so should be good.
Позже ([time]15 Января, 2014, 18:01[/time]) добавлено:
Thanks! I will try and find the template he made on a cereal box :), but there is no real measurements though. The old man got a good eye!
« Last Edit: 15/01/14 by volvarine »
