Author Topic: All the way from South Africa  (Read 133433 times)
« Reply #260 on: 29/11/12 »
Антоха, разницы нет... TD04 after TF035 - bolt-on!
Offline PapaKGB
  • 2хYRV Turbo RED&BLACK
« Reply #261 on: 29/11/12 »
Юра, а было же где-то не тут твое все с описанием, кста-ти нашел чё за косяк с моей турбой, при перегреве видно коллектор повело, и на бусте подтравливает где-то, шлифовка, и новые прокладки вроде говорят. А турбина один фиг 0.9 и сдувается на 0,7 как бы прыгает туда сюда, контрактная стабильно 1 дула, так, что турбине весной приговор.
Offline volvarine
« Reply #262 on: 29/11/12 »
yes the exhaust manifold will be build definately, I am thinking GT25! Will the GT28 be too big?
What about these? What AR must it be? Examples below
COMPRESSOR HOUSING AR.60
COMPRESSOR WHEEL 54.2MM
TURBINE HOUSING AR.64
TURBINE WHEEL 46.9MM
« Reply #263 on: 29/11/12 »
IMHO, gt28 too big for k3-vet.
300hp for FWD - excessive demands on tires, huge load for automatic transmission.
Offline PapaKGB
« Reply #264 on: 30/11/12 »
T4 )))))
Offline volvarine
« Reply #265 on: 02/12/12 »
ok so how do I spec the GT25 so that it is the right AR?
Offline PapaKGB
« Reply #266 on: 03/12/12 »
what's AR? air ratio?
Offline volvarine
« Reply #267 on: 03/12/12 »
Area Ratio
Позже ([time]03 декабря, 2012, 11:12[/time]) добавлено:
Is there a YRV 4WD? I am thinking it would be nice to convert it to an 4WD since traction is a problem on these cars.
How difficult would it be to convert it?
« Reply #268 on: 03/12/12 »
Rather difficult diffrence beetwen rear part of car.. A lot of custom work...
Offline PapaKGB
« Reply #269 on: 03/12/12 »
чё гонишь? - гемор в баке.
It's not difficult if you get hold of 4WD parts at once.
Custom work is only with an exaust outlet, its a bit different.
The worst thing is you will have to get 4WD gearbox, there is a cheaper way, but u have to get gearbox out anyway and open it, to put a differential in.
You will also need a 4wd fuel tank, axels, drive shafts, propeller shaft...- it'll be pretty expensive.
4WD - sux, it's a way slower. Get a wider tires bro, some1 overseas had pulled 18"s in it. That will be cheaper
« Last Edit: 03/12/12 by PapaKGB »
« Reply #270 on: 03/12/12 »
Антоха, точки крепления балки и моста - разные, поперечина под корытом запаски - тоже отличается (на m201 нету усилителя, к которому крепится тяга Панара)
« Reply #271 on: 03/12/12 »
мне кажется я лучше знаю различия.....
Offline volvarine
« Reply #272 on: 03/12/12 »
18"? How did he manage that? i want to put 17" on but battle to do it? What must I change to get 17" on the car?
With the Tein drop it catch in front when I hit a bump and this is with the 15"s on
« Last Edit: 03/12/12 by volvarine »
Offline PapaKGB
« Reply #273 on: 03/12/12 »
кароче молчу...у меня донор был со всей херней -уперся в отсуствие бака - передумал, прокатился на вд-ом ещё и с 0,7 ваще ацтой. Я к чему - сделать можно всё, только он это хер сделает - а сделает - пасссссмотрим )))))))
that one - "green goblin" http://avtozane.com/image/11f197ad
http://digitalproject-toycar.blogspot.ru/2011/12/yrv-interior-exterior-stance-fitment.html - 18",
- а наши пусть плюются - дорог у нас таких нет )))))))
http://daihatsutuning.com/ - that one is like yours
Позже (03/12/12) добавлено:
весьма с тобой согласен...про вовкину коробку особенно.
« Reply #274 on: 09/12/12 »
Если бы гемор был только в баке, я уже давно б 4ВД сделал.
Юрц верно сказал всё.
Так-то не гони, в общем.
Offline PapaKGB
« Reply #275 on: 16/12/12 »
блин да всё можно сделать если руки не из попы, чего гнать, запарились типы в москве - причём солидный тюнинг ателье - сделали 9-ку вдовую, там не только точки крепления были...у нас меньше гемора при наличии донора теоретически не сложно - просто нах? проще купить вдовую и переставить ништяки на неё. А от машины кайфую летом и то когда сухо, но у 4вд динамика уже не та.
« Reply #276 on: 16/12/12 »
В подмосковье есть 99 - сти лиса, от 99 только кузов...
« Reply #277 on: 16/12/12 »
Макс, там только навесные панели от 99, а остальное все - от субы и самопал.
Антоха, вообще о чем споришь? сделать можно все, но ты сам сказал -
гемор в баке.
бак вообще не проблема. Как и раздатка с мостом.
Offline PapaKGB
« Reply #278 on: 16/12/12 »
когда эту тему года 4 назад поднимали, я как раз один из первых вэдовку корячил не хотел её разбирать, и лежало ещё все железо, подвсека, привода итд, не было бака - сами где-то и говорили, что хер его с япи привезу - я это не придумал ))) курить больше надо - или меньше.
кароче бесполезно дальше развивать - бедный друг с африки - чёго ему гугл переведёт.
Раздатка новая лежит - забирайте за разумное лавэ или на пластик и мелочь, поменяю.
« Reply #279 on: 17/12/12 »
раздаток у меня штук 5 есть еще, на каждое колесо можно по раздатке повесить, вместе с запаской.
Бак можно сделать и самопальный - не такая сложность...
2wd (балка крепится прямо у задней части порога)
4wd (рычаг крепится примерно под серединой задней двери)
