Author Topic: All the way from South Africa  (Read 133796 times)
« Reply #360 on: 18/02/16 »
White smoke = broken engine gasket
antifreeze gets into the cylinders
« Reply #361 on: 19/02/16 »
Вань, у него дымит при ускорении, это не прокладка.
Offline volvarine
« Reply #362 on: 19/02/16 »
It is definitely not head gasket. It's not using water just oil. If it is valve stem seals it will smoke on idle or when you take your foot of the gas right? I am guessing either a valve or rings?
« Reply #363 on: 19/02/16 »
Try to replace the valve seal . White or blue smoke?
Offline volvarine
« Reply #364 on: 19/02/16 »
It looks more blue than white
« Reply #365 on: 19/02/16 »
under acceleration = rings or turbocharger
On idle = valve stem seals
« Reply #366 on: 19/02/16 »
Offline volvarine
« Reply #367 on: 10/03/16 »
Where can I buy good rings and bearings?
« Reply #368 on: 14/03/16 »
Hi. The forum has moved to  [link removed, forum not moved. administration]
« Last Edit: 04/07/17 by YDoron »
Offline volvarine
Re: All the way from South Africa
« Reply #369 on: 04/07/17 »
Wassup guys! Anyone experiencing low brake pedal? It was always like that on my car but it is annoying me now. How can I fix it?
Offline volvarine
« Reply #370 on: 08/09/20 »
Hi guys hope everything is well! Please tell me if i can raise my yrv rev limiter? Motor is still stock, but will it be save to raise the limiter by 500 rpms
