Author Topic: All the way from South Africa  (Read 133319 times)
« Reply #140 on: 21/01/10 »
whatever...
Only thing I can`t figure out, is how to choose right IHI turbocharger - I do not see any additional indexes, for RHF4 or RHF3. Does it mean that RHF4 will always the same RHF4 for any vehicle? For example, Garrett GT25 series turbos has the same turbine, but different size of air compressor (GT2540, GT2554, GT2560).
Volvarine
« Reply #141 on: 21/01/10 »
I was also wondering about that. Seems like they don't
Offline ROJER
« Reply #142 on: 22/01/10 »
uran on my gt25 more than he knows nothing.
rhf5 has almost the same performance as rhf4.
You need a turbine with a cartridge rhf55, it will be ihi vf37, as the best option would be a series td04 you put on Forester 2.0 turbo
« Reply #143 on: 22/01/10 »
чёт ты там про меня пукнул?... :D
Offline ROJER
« Reply #144 on: 23/01/10 »
говорю gt25 просто ахуе*ая серия для моторов 1,3 в целом !! :D
Volvarine
« Reply #145 on: 25/01/10 »
I had a closer look at my turbo and ja it is a RHF4, when I looked at the turbo a long time ago I couldn't see the plate that well only the codes. I don't undertsand that the codes they put on the turbo, when doing a inetrnet search says it is a RHF3.
« Reply #146 on: 25/01/10 »
And I'm talking about the same
Volvarine
« Reply #147 on: 05/02/10 »
Here is a little video of me playing.
http://www.youtube.com/watch?v=49RiydmGE1E
Volvarine
« Reply #148 on: 19/02/10 »
I want to replace my gearbox oil with something better, any suggestions? How much litres does it take?
Offline To4e4ka
« Reply #149 on: 19/02/10 »
Replace your A/T with M/T: this is the best choice ;)
А.Б.Зингер
« Reply #150 on: 19/02/10 »
As i remember, full capacity of gear box iss 4,5 litres... But i don't remember the replacement capacity..  use dextron3... Others people may say more about this problem...
« Reply #151 on: 19/02/10 »
full capacity is 5 liters, but you will not drain more than 2 liters from drain hole
Volvarine
« Reply #153 on: 19/02/10 »
Maybe in the future I will look at doing this.
Volvarine
« Reply #154 on: 19/02/10 »
so it must be flushed out or something?
« Reply #156 on: 19/02/10 »
Update liquid:
1) 2 liter pour from GearBox, pour 2 liters to GearBox
2) engine plant, the transfer switch ...
3) if you want to go para 1)
Offline PapaKGB
  • 2хYRV Turbo RED&BLACK
« Reply #157 on: 19/02/10 »
did i miss anything?
Volvarine
« Reply #158 on: 20/02/10 »
There is nothing wrong with my gearbox, the car almost got 60000km on the clock, I just want to replace the oil for good measure.
I went racing at our local track last night and got a new personal best on the 400m. I did a 14.8s!
« Reply #159 on: 20/02/10 »
14.8s!
m-m-m.
Very-very...
But...is something to aspire
« Last Edit: 20/02/10 by Yurz »
