Author Topic: All the way from South Africa  (Read 133282 times)
Volvarine
« Reply #120 on: 20/01/10 »
This is what I got of my turbo.
Turbo code: VC420039
OEM Turbo code : 17200-97401-C
http://www.turbo-product.com/IHI/RHF3.ASP
« Reply #121 on: 20/01/10 »
MY STOCK.
Volvarine
« Reply #122 on: 20/01/10 »
MY STOCK.
mmmmm...... Interesting! This is weird!
« Reply #123 on: 20/01/10 »
обделили пацанов...
« Reply #124 on: 20/01/10 »
Hm... according to this page - http://www.turbo-product.com/IHI/RHF4.ASP - RHF4 is used for smaller (660 cm3) Daihatsu engines EF-DET and JB-DET
Yurz, tell us the truth - what engine do you have ;D
« Reply #125 on: 20/01/10 »
Such turbine is put on all YRV turbo which I saw
In other words, on the engine k3-vet
http://toyota.japancats.ru/details.asp?carid=203&modelcode=9&treg=J&vin=&frame1=&frame2=&piid=20675
« Last Edit: 20/01/10 by Yurz »
Volvarine
« Reply #126 on: 21/01/10 »
I am going to look at a RHF5 turbo next week. Do you guys think it could work nicely on the YRV?
« Reply #127 on: 21/01/10 »
Приезжай на ЯРВишник - раскажем! ;)
« Reply #128 on: 21/01/10 »
Quote from: Volvarine
As far I know, there is no such experience yet. Does it has the same flange like RHF3?
Volvarine
« Reply #129 on: 21/01/10 »
I think it does but not 100% sure, I will check for that. Do you think the RHF5 will be to big for the 1300cc?
« Reply #130 on: 21/01/10 »
Do not know... Garrett has table chart for their turbos with engine capacities in it. Try to find something like this for IHI.
Volvarine
« Reply #131 on: 21/01/10 »
http://www.ihi-turbo.com/turbo_RHE-RHF.htm
Looks like from 1.5l onwards, should be fine.
« Reply #132 on: 21/01/10 »
why bind to RHF3? Someone once overlooked, and off they'd go ...
I checked on YRV-meet this moment (to be amputated version of my "nonStandarD stock")
FOR MOTOR K3-VET standing up with the factory RHF4 !!![/ b] And YRV and CAMI / TERIOS!!!
« Last Edit: 21/01/10 by Yurz »
« Reply #133 on: 21/01/10 »
it would too big if you are going to use stock engine settings, otherwise it will depend on your ability to find optimal settings for boost and piggyback controllers
« Reply #134 on: 21/01/10 »
но у него-то RHF3 :)
« Reply #135 on: 21/01/10 »
Where is the evidence?
« Reply #136 on: 21/01/10 »
я! сам! ездил! в! ЮАР! и! проверил! :D ну чего пристал? окажется что у него тоже RHF4, тогда всё вышенаписанное будет относиться к совместительству фланцев RHF4 и RHF5. суть не меняется
« Reply #137 on: 21/01/10 »
Yes, I even gave a link (at CAMI c VET), there is the original number with my match.
Our hot "snail" is so small that it is unlikely that there is something more with the same size flanges.
« Reply #138 on: 21/01/10 »
Quote from: Yurz
НА МОТОР K3-VET СТАВИТСЯ с завода RHF4 !!! И на YRV и на CAMI/TERIOS !!!
кстати, а ты ездил проверял? :) чего ты так уверен? возможно были эксперименты и ставили обе турбины
« Reply #139 on: 21/01/10 »
http://www.yrv.ru/forum/index.php/topic,8076.msg213027.html#msg213027
Tested on machines of different years of manufacture / type of drive.
