Клубная движуха
International corner
All the way from South Africa
18
19
Topic: All the way from South Africa (Read 129093 times)
ZM
В ритме YRV в темпе Turbo
Reply #360 on:
18/02/16 »
White smoke = broken engine gasket
antifreeze gets into the cylinders
чОрный
Антон
Reply #361 on:
19/02/16 »
Вань, у него дымит при ускорении, это не прокладка.
Про моего
чОрного
Про второго
чОрного
Ярик
volvarine
ЯРВюга
Reply #362 on:
19/02/16 »
It is definitely not head gasket. It's not using water just oil. If it is valve stem seals it will smoke on idle or when you take your foot of the gas right? I am guessing either a valve or rings?
чОрный
Антон
Reply #363 on:
19/02/16 »
Try to replace the valve seal . White or blue smoke?
Про моего
чОрного
Про второго
чОрного
Ярик
volvarine
ЯРВюга
Reply #364 on:
19/02/16 »
It looks more blue than white
чОрный
Антон
Reply #365 on:
19/02/16 »
under acceleration = rings or turbocharger
On idle = valve stem seals
Про моего
чОрного
Про второго
чОрного
Ярик
Reply #366 on:
19/02/16 »
volvarine
ЯРВюга
Reply #367 on:
10/03/16 »
Where can I buy good rings and bearings?
russamael
Reply #368 on:
14/03/16 »
Hi. The forum has moved to [
link removed, forum not moved. administration
Last Edit: 04/07/17 by YDoron
volvarine
ЯРВюга
Re: All the way from South Africa
Reply #369 on:
04/07/17 »
Wassup guys! Anyone experiencing low brake pedal? It was always like that on my car but it is annoying me now. How can I fix it?
volvarine
ЯРВюга
Reply #370 on:
08/09/20 »
Hi guys hope everything is well! Please tell me if i can raise my yrv rev limiter? Motor is still stock, but will it be save to raise the limiter by 500 rpms
18
19
Клубная движуха
