Author Topic: All the way from South Africa  (Read 133532 times)
« Reply #340 on: 25/11/14 »
hmm... 1jz-gte - 380cc, 2jz-gte - 430cc...
Offline volvarine
« Reply #341 on: 26/11/14 »
I think this guys selling the injectors had 440cc in his 1jz-gte and they weren't oem. I will have them tested.
Позже (26/11/14) добавлено:
« Last Edit: 26/11/14 by volvarine »
Offline volvarine
« Reply #342 on: 02/06/15 »
Hi guys! Anyone have a photo of the fuel pump disassembled with some sizes like length, diameter etc. I want to upgrade mine but want to get something that will still fit into the casing
Позже ([time]02 Июня, 2015, 10:07[/time]) добавлено:
Some pics of how it looks currently. Still need to take her for a tune.
Volvo S40 Intercooler
Позже (02/06/15) добавлено:
I want to to get something like this. I want it to fit in the current case, will it? here is the sizes and specs
Technical Specs:
    Weight: 10.1oz (285grams)
    Outside Diameter: 39mm OD
    External Materials: Black plated steel with laser etching
    Inlet Fitting: 7.7mm ID, 11.0mm OD
    Outlet Fitting: 8 mm hose clamp
    PRV Activation: 90 PSI
    Impeller Design: Single Scroll Hard Anodized Aluminum Turbine
« Last Edit: 02/06/15 by volvarine »
Offline Djon-GT
  • пыщ-пыщ
« Reply #343 on: 02/06/15 »
Wow :o
« Reply #344 on: 02/06/15 »
I recommend replacing the power wires to pump thicker.
What results recorded?   Methanol injection see ))
Offline deboom
  • DHT YRV 1.3t 4WD
« Reply #345 on: 02/06/15 »
Offline volvarine
« Reply #346 on: 03/06/15 »
Good idea I will look into that.
I don't have any results yet want to upgrade fuel system first. Methanol makes a big difference.
Позже (03/06/15) добавлено:
thank you!
Offline volvarine
« Reply #347 on: 05/06/15 »
I see the car is idling low. It also don't see the coldstart idling higher either.
I've cleaned the idle control valve before but didn't make much of a difference
Offline volvarine
« Reply #348 on: 04/08/15 »
I am trying to remove the idle control valve but don't seem to get the right size torx for it. The T15 is to small and the T20 is to big. Where can i get the right size and what is the right size?
« Reply #349 on: 04/08/15 »
the same 5-pointed head is needed instead of a 6- pointed Star ( Torx ) .
Some have spun a flat screwdriver ( pre- slotted Dremel ) .
Offline volvarine
« Reply #350 on: 04/08/15 »
ok cool thanks Yurz!
Offline volvarine
« Reply #351 on: 12/09/15 »
Is it possible to access the fuel pump from inside the car or must I drop the fuel tank?
Offline deboom
  • DHT YRV 1.3t 4WD
« Reply #352 on: 12/09/15 »
 must drop the fuel tank
Offline volvarine
« Reply #353 on: 12/09/15 »
Ok thanks
Offline IceMaN
  • Джипарист на пузотёрке! =)
« Reply #354 on: 12/09/15 »
here you can see some pictures, how to do that http://yrv.ru/forum/index.php/topic,16440.100.html
Suzuki GrandVitara 2001
Offline volvarine
« Reply #355 on: 12/09/15 »
Great stuff thanks!
Offline volvarine
« Reply #356 on: 31/12/15 »
I had my car tuned with the gt28. Turbo is too big! It just manage to get 1 bar out of it at 7500rpms. Staying in Johannesburg 1700m above sea level don't help the spooling of the turbo either. It made 131kw and 187nm at the wheels.
Позже ([time]31 Декабря, 2015, 14:03[/time]) добавлено:
Позже (31/12/15) добавлено:
« Last Edit: 31/12/15 by volvarine »
« Reply #357 on: 31/12/15 »
an excellent result , congratulations. I`m waiting for the results from the drag strip
Offline volvarine
« Reply #358 on: 31/12/15 »
I will go to the strip soon. Car is very sluggish of the line.
Still need to fit another downpipe and flow the head
Offline volvarine
« Reply #359 on: 18/02/16 »
Car is smoking under acceleration.  Blou white smoke. What could be the cause? Rings maybe?
