Author Topic: Проверка бензонасоса  (Read 1471 times)
Offline DenisJX
Всем привет! Машина резко перестала заводиться, с утра еще заводилась, а днем уже нет. Реле под капотом щелкает, а насос не гудит... Как проверить насос напрямую не снимая бака?
YRV 1.3 атмо + Lexus is200
Offline ethelbertmagnus
Re: Проверка бензонасоса
« Reply #1 on: 10/02/22 »
5 Vacuum Cleaning Tips Everyone Should Know
There are numerous easy and helpful cleaning solutions to rid your house of microscopic mites, germs, and dust. You can try picking up the clutter or disinfecting the countertops; these are useful activities. However, there is no denying that the best method of home cleaning is cleaning with a vacuum cleaner. Today, we are going to focus on five useful tips on vacuum cleaning your house.
Selected For You: Best rated vacuum cleaners Thekinglive.com
1. Make sure you’ve vacuumed multiple times in the same area
When you try to pull up the pet hair and dust from your floor, bear in mind that once is not enough to get it all. To get an area completely clean, you need to run your vacuum over that area several times and from different directions. By doing this, the debris and dirt can be pulled entirely up from the surface you are cleaning.
If you own a pet, you would have noticed that their fur is a considerable annoyance even with the best pet vacuum cleaners. Pet hair tends to take at least ten passes when cleaning with vacuum cleaners. Also, if you don’t have any pets, it is still advised that you go over the carpet numerous times from different directions.
2. Try to put things in a simple way
The second vacuum cleaning tip is probably well known among vacuum cleaner users — don’t make the cleaning job harder than it should be. It could surprise you seeing how many people can create messes that make vacuuming harder than it should be.
Picked For You: Best Vacuum Cleaner Reviews
3. Create a Schedule
Creating a schedule and sticking to it is also another critical vacuum cleaning tip. By doing this, you can ensure that the floors and other surfaces in your living space are clean all the time.
The regularity of your schedule can vary, and it mostly depends on your living area. For most homes, vacuuming one or two times each week is enough. However, you might need to take a little bit more effort if your house has areas with high traffic. For homes with pets that shed quite often, vacuum cleaning needs to be done more than once a week. The same schedule should be applied for houses that have naughty kids who dirty the house all the time.
4. Don’t forget to empty the canister or change the bag in your vacuum
This tip is also an obvious tip that everyone might already know. Pay attention to and take care of your vacuum cleaner’s bag or canister regularly.
When the canister or bag of your vacuum cleaner is full, it would be hard to vacuum the floors or other surfaces effectively. Therefore, remember to empty or change the bag or canister every time you vacuum, or else you will have to waste a lot of time trying to get your house clean because the suction power of a full machine drops significantly. Vacuum cleaners with a bag or canister full of dirt simply cannot perform well. They can even cause a bigger mess because the dust they tried to suck in cannot enter the vacuum and gets blown around the room.
5. Spot Treat
Most homeowners do not want stains on the carpets in their house. Therefore, when you accidentally spill something on your carpet, take care of it right away. This action will help minimize the likelihood of a long-term stain. If you are vacuuming the carpet and find stains on it, we advise you to treat them with a spot cleaner. Whether the stains are old or new, a steam cleaner can come in handy and help remove some of them. Spot cleaners are always the better option in most cases, but a steam cleaner can work just as well!
Useful Link: https://www.linkedin.com/showcase/best-vacuum-cleaner-in-the-world-reviews/
Conclusion
When it comes to keeping the floors of your house clean, vacuum cleaners are always the most valuable tools. You cannot own a home and not have a vacuum cleaner to do the cleaning job. Our team at TheKingLive.com will assume that you have already had at least one vacuum cleaner at your house and share with you the tips on vacuum cleaning.
« Last Edit: 22/03/23 by ethelbertmagnus »
