Author Topic: Rear wheel bearing for 4wd  (Read 2434 times)
Offline srbija
« on: 30/12/15 »
Hi.
I´m having problem whit squealing noise from rear wheels whan turning in corners. Found that some one have the same problem on forum but google translate wasn´t helpfull enough. It´s probably rear wheel bearings. So if anyone could give me part number and dimensions i would be very gratefull. On internet is easy to find bearing for 2wd, but for 4wd is very little information and same bearings that are mentioned seem to small (iner dimension of bearing is smaller than shaft diametar).
Buy
« Reply #1 on: 30/12/15 »
for 4wd 90043-63249
Offline srbija
« Reply #2 on: 30/12/15 »
Thank you a lot.
Позже (30/12/15) добавлено:
By this part number two sizes could be found 30x62x20 and 31x62x20 mm. Does any know the actual size?
« Last Edit: 30/12/15 by srbija »
Offline bubaleh
  • Миша
« Reply #3 on: 30/12/15 »
Hi. Kit for 4wd
Offline srbija
« Reply #4 on: 30/01/16 »
Hi,
this bearing is impossible to find in Serbia. Can someone post more pictures of bearing and if possible some pictures of dismantling process. What type of bearing is it? First is it ball bearing, single or double row? Or is it same kind of two piece bearing... As I see on pictures above it looks that only one side is sealed? Only what I can find in Serbia is 62206 2RS bearing, but  dont know does it suits...
Offline bubaleh
  • Миша
« Reply #5 on: 30/01/16 »
One bearing on the right and one on the left . only 4 wd.
I have not installed yet
Offline srbija
« Reply #6 on: 30/01/16 »
Yes I know that is one bearing on each side, I need the type of bearing and pictures to see could it be replaced which some common bearing which I could find in Serbia... Could you post some more pictures of bearing without nylon on it?
« Reply #7 on: 30/01/16 »
Only one side is sealed.
Dimensions: 31x62x20
Offline srbija
« Reply #8 on: 30/01/16 »
I found those pictures, dimension somewhere is 30x62x20, on other places is 31x62x20. Is this mean that differencial oil is lubricating bearing, what for seal is used than??? The main thing that I need to know is is thickness of bearing is 20mm in inner and outer ring? Is it ball or Tapered Roller Bearing type?
