Author Topic: All the way from South Africa  (Read 133244 times)
« Reply #60 on: 30/12/09 »
Quote from: Volvarine
The water/meth injection - Price ZAR4500 including installation and tuning
Thank a lot for your pics! ;) As I can see, you bought some kit from this list - http://www.snowperformance.net/products.php?p_cat=324 - please, specify which one you are using and how do you manage it`s settings
« Reply #61 on: 30/12/09 »
oh ok! as far a I know the UniQ doesn't use the MAP, you connect the pressure hose directly to it so that it can map the fuel correctly, it takes the stock ecu maps and then you add say 10% more fuel as an example. The unichip is a piggyback that goes onto your cars ECU. I hope this answers your question.
UniQ works like apexi safc (or blitz r-fit). am i right?
what rpm limitations you have with your device?
Volvarine
« Reply #62 on: 30/12/09 »
It is basicly a stage 1 kit
http://translate.googleusercontent.com/translate_c?hl=en&ie=UTF-8&sl=ru&tl=en&u=http://www.snowperformance.net/product.php%3Fpk%3D83&prev=_t&rurl=translate.google.co.za&usg=ALkJrhhNOurPcYETQpe8RThjiMfaW547Sw
The pump is activated by my Unichip, at 0.8bar and at +-4500rpms, it is either on or off very simple, you get progressive systems which will control the flow of the pump but they cost more.  If you don't use unichip you probably get with the kit or have to buy a hobb switch to set it to the boost level you want to to come on.
Volvarine
« Reply #63 on: 30/12/09 »
I am not to clued up on the technical aspects of the UniQ but it is basicly does te same job as apexi safc (or blitz r-fit). If I understand your question correctly it maps every 250 rpms...i think :)
« Reply #64 on: 30/12/09 »
i'm ask about fuel cutoff.
Offline Drv
« Reply #65 on: 30/12/09 »
From the spec given, I think Unichip is even better than E-manage Ultimate :) It could not be compared with SAFC.
Volvarine
« Reply #66 on: 30/12/09 »
I had a problem with that but the UniQ fooled it.
Volvarine
« Reply #67 on: 30/12/09 »
I am now really motivated to replace that turbo and getting a bigger intercooler!!! What size downpipe and exhaust you guys running on the Garrett turbos? What octane fuel you guys got in Russia? You running racing fuel too?
« Reply #68 on: 30/12/09 »
usually we use "premium" (95) or "super" (98) fuel.
special racing fuel costs too much :(
Offline Drv
« Reply #69 on: 30/12/09 »
Only 98. Never tried race fuel, but it is possible to buy here 102, 106 even 116. Price is approx USD 4 per ltr.
Regarding pipes. I`am using standard exhaust, without cats and slightly improved muffler :) (don`t like noise).
Intake pipes - not so important, you can take FMIC and make assembling with required pipes, the same dia as new cooler intake.
« Reply #70 on: 30/12/09 »
Diameter is 61 cm. See this album from begining for details - http://foto.drom.ru/7107/
Offline ROJER
« Reply #71 on: 30/12/09 »
Greetings, it is not absolutely correct so to put the filter on ventilation of crankcase fumes, these gases are extended by an uncharging created in front of the turbine, can squeeze out epiploons...
I adjusted the car thus, to 1 bar - 95 gasoline, 1,2 bar - 98 only though children use my adjusted blocks and on 95 gasoline, quality of fuel a miscellaneous
еманж так же можно научить прыскать, привязав к оборотам, наддуву и т.д.
Volvarine
« Reply #72 on: 30/12/09 »
That red YRV looks wicked!
Volvarine
« Reply #73 on: 30/12/09 »
Mine is 57mm with 2 boxes and it still sounded like the stock pipe, I removed 1 box now so that it got a bit of a growl now :)
« Reply #74 on: 30/12/09 »
Red - they such :)
Volvarine
« Reply #75 on: 30/12/09 »
True the filter isn't the best idea.
Volvarine
« Reply #77 on: 30/12/09 »
Volvarine
« Reply #78 on: 30/12/09 »
any of you guys upgraded your YRVs swaybars?
