Клубная движуха => International corner => Topic started by: srbija on 07/02/15
Hi! Can someone tell me is 4wd permanent on Yrv, or is being engaged / disengaged by something (slip, steering angle, speed, gear)? And how coupling is being performed. I have found different explanation on web but none seams convincing. Thanks ahead!
Full time. Viscous clutch
http://yrv.ru/forum/index.php/topic,19900.msg718494.html#msg718494
As I saw it on the link you gave, in normal conditions (without the slip) coupling is none or very little. And there is nothing else except metal disks and viscous liquid in coupling. Thanks a lot!
exactly so
