Клубная движуха => International corner => Topic started by: srbija on 15/02/13
Da li je moguce zameniti sijalicu na preglednoj tabli?
Is it possible to change background light bulb on metar board?
Можно ли изменить лампа подсветки на METAR борту? -Google translate
did you mean "meter board"? you will find such bulb caps at the back side of the dashboard - http://yrv.ru/forum/index.php/topic,11248.msg330431.html#msg330431
p.s. Any bulb could be replaced
Ok. Thanks. I wasn't sure is it bulbs or diodes. I just hope it is same standard ones, because it is impossible to find anything extraordinary in Serbia. This site is very, very good, i was on same english sites but there u couldn't find anything.
There are both bulbs and leds inside of dashboard. Bulbs for lighting, leds for indicators. You can download Service Manual from here - http://yrv.ru/service-manual/
Thanks for replays. I am trying to open Microcat, but only getting some out of date notification can't start. I can't read the "read me" file :-) maybe because is on cyrillic i just recognized the Uran signature in the end of file. So, can u tell me what to do Uranus? I tried it on win 7 and XP sp3...
I do not remember clearly... something like "replace some file, then, change year at 2008 on your PC"... if you can see "out of date" message, try to change year first
Not sure will it work for IP outside of Russia, but you can try this online Daihatsu spare parts catalogue - http://www.japancats.ru/Daihatsu/Group.aspx?Model=ac4ccf61-f669-4155-b62f-b3907eb8f863&Title=YRV%20M200/201/211#g&n0 - registration via SMS required
