Клубная движуха => International corner => : rong4356 05/09/10
Hi everyone , im for Malaysia , i have a problem with my auto transmission gearbox. when i put to reverse gear my engine and gearbox will jerk and clunk , R-gear delay abort 2 sec. Hope every expert can help. thanks
Well ... epidemic again.
Planetary gear. In her broken bolts in the end - this is such a problem arises.
HI . Use translator http://www.yrv.ru/forum/index.php/topic,6789.0.html
http://translate.google.ru
thanks for reply , i still cant get full details with translator . means i have to overhaul my gearbox or problem with valve body ? please advice.
http://www.yrv.ru/forum/index.php/topic,6789.msg159432.html#msg159432
год какой?
I'm not sure , because i'm buy a half cut YRV turbo in my country , import from japan , maybe is 2002.
You have to remove the gearbox and disassemble!
And to be sure, first remove the bottom cover and look at the magnet, if it is in the metal shavings, then remove the box without thinking!
ps stop the exploitation
or is Turbine and Output revolution sensor problem?
I dont think so.
there is no wonders in this world
But once i restart my car , it will working fine.
